Speaker mounting depth
  • Good morning,
    I would like to know if anyone knows the maximum mounting depth of the speakers in the doors and which adapters I need to buy to replace the original speakers.
    How can I access the tweeters? Do I have to disassemble the whole dashboard? Is there a guide for this?
    Thanks for the replies. I am Italian and I don't speak Deutsch. Davide
  • Ciao Davide,
    the tweeters are only accessable from under the dashboard. Sorry.
    But if you want to upgrade your system anyway, leave the OEM-Tweeters where they are and put new ones where you like it. (perhaps mirror triangle)
    If your door already has the fixure for speakers, there will fit 6" Speakers with a mounting depth of approx. 50mm.
    Check out these (similar version should be avalable in Italy):
    Hertz 165mm 2-Way
    ...at least the dimensions of this set will give you an idea...
    * Unsere Seite enthält Affiliate-Links, für die unser Forum möglicherweise eine Vergütung bekommt.
  • The tweeters are only accessible from underneath and require the dashboard to be moved back a couple of inches. I’ve done it a few times, not a nice way to spend half a day plus needs quite a selection of tools.
    I don’t have a complete guide, just work your way forward from the cup holder between the seats.
    :thumbsup: Renault Twingo 3 TCe 90 Dynamique, Bj 01/2015 :thumbsup:
    R&Go DAB :thumbdown: mit nachgerüsteter Aktivantenne :thumbsup:
  • 20cm in the doors would be a hard challenge...if you want to take it...
    Check out the max diameter of the speaker grill. You might need to mount the 8"-speakers from outside and you might also need appropriate covers.
    From my point of view, you should invest in a good pair of 6"-speakers and good damping of the doors. This way you at least don't have to cut the doorpanels.
  • Ok but all the real good 6'' speakers are more deep than 50mm... Am i wrong?
    Might be.
    But a 8" has a even higher depth.
    The only way to find out if a speaker fits, is to remove the Doorpanel and to measure the depth. (or anybody already knows here)
